RCU Forums - View Single Post - From the Archives "The way it used to be"
Old 04-11-2003 | 04:48 AM
MikeC-RCU
Default Re: From the Archives "The way it used to be"
Originally posted by Countryboy
Looking at that article and viewing the setup shows how things change rapidly. With todays new door sequencers, it makes Mike's system sort of absolute. .......
Hi Countryboy,
I guess you meant to say OBSOLETE instead of ABSOLUTE !
The system I showed back in '97 worked fine, and still does, for those that don't want to use the latest (ie:more $$$) electronic sequencing gadgets etc - and for those modellers that can build and set-up a properly engineered door and gear sequencing system with simple and low-cost gear!
.. and by the way, I'm still using it!
Mike C
