RCU Forums - View Single Post - Ultrastick 40 questions
Old 04-11-2003 | 09:10 AM
jjmiller1
Default Ultrastick 40 questions
Replace the aluminum ingot of an engine mount with a fiberglass mount, and tuck the engine as close to the firewall as you comfortably can.This got mine much closer to the desired CG.Then again, I don't know if your engine is heavier. I still had to add an ounce to the tail to get to the aft side of the specified range.
Good luck
JJ
