Ultrastick 40 questions >
Old 04-11-2003 | 04:25 AM
Default Ultrastick 40 questions
Got an Ultrastick 40 from my sweetie for Xmas and am gettin it ready to fly after I warm up on my Avistar but I am perplexed by the nose heavy set up I have it looks like I will have to do surgery on it to put the battery back far enough to get a good CG. has anybody had this problem? And does naybody have some suggestions on how to fix it without surgery?I am using a ST gs45 engine on it.
Old 04-11-2003 | 04:38 AM
easysport:
Do a search on "Ultrastick." There was a very active thread on this plane, telling the weak points to address.
HTH
Bill.
Old 04-11-2003 | 09:10 AM
Replace the aluminum ingot of an engine mount with a fiberglass mount, and tuck the engine as close to the firewall as you comfortably can.This got mine much closer to the desired CG.Then again, I don't know if your engine is heavier. I still had to add an ounce to the tail to get to the aft side of the specified range.
Good luck
JJ
Old 04-11-2003 | 02:54 PM
Thanks for the info JJ and Avistars also float upside down very well too and don't ask either
Old 04-14-2003 | 12:02 AM
http://www.rcuniverse.com/showthread...737#post831670
A similar question that I answered, Look for my posts and pictures to help you out, adding weight is the last thing you want to do. Good luck
Alexx
Old 04-14-2003 | 12:13 AM
Default us 40
i had to add a couple ounces of tail weight to mine. i run a thunder tiger pro 46 w/ a macs pipe. it definately has unlimited vertical !
conk
