RCU Forums - View Single Post - SIMJET 1700
Thread: SIMJET 1700
Old 01-09-2008 | 10:57 AM
Vampire
Default RE: SIMJET 1700
jephry,
It appears that you have discovered the problem.
The temps indicated are in Celcius. Idle shoudl be approx, 450 to 600 C and Max 700 to 760 C.
To Claibrate the T/C, remove the front engine cover, and you wil see a small terminal block to which the T/C wires are inserted.
NEXT to this terminal block is a very small, square block with a very screw in the side of it. This is used to adjust the T/C calibration.
Using your Data terminal, turn on your ecu and you should be reading curent air temperature minus 2 degrees or so. If not, adjust this screw until you do. Tempurature is in Celcius
Kerry J. Sterner
US SIMJET LLC
