ORIGINAL: HpiDrifter420
its to low to the ground and mud is an uneven surface the car will bottom out
i have got nearly 2cm ground clearance fully loaded (with battery)
it doesn't sound like much, but compared to my racing TT-01, which has 4mm clearance, with no battery in
i went to the place i will use t on the weekend, and the biggest gravel is about 10 - 15mm, so i should be fine with it
