RE: Speed Freaks Wanted- Over 150 Members already !
I've even heard of guys adding a tablespoon of gasoline to their glowfuel for cold weather flying. I'm sure as heck not going to experiment with a $400 racing engine but maybe on a clunker motor. I have tried the turbine oil with no noticeable increase in performance on a standard O.S. 46 FX. I have found that if you try hard enough you can blow up any engine if you push it hard enough! I do know one thing. If you take apart an engine and the bearings say made in China? Throw them in the trash. Bearings made in Japan and USA are fine. If you have an engine made in China...the bearings are made there also. Even the Japaneese will not put Chineese bearings in their engines. Buy cheap bearings and cheap bearings you will get! Speedy
