power for sig se
Gshephard83,
The OS46FX is a good choice for this airframe. It probably was design around it in fact. As this is your 2nd plane, and hovering may be a little bit down the road, it is a perfect match. If built light, the 46 should hover without a problem when you get to that point. Putting on a V8 in a pinto isn't always the best combination when learning to drive. I'd say save your $$ and go with the OS. You wont be disapointed. MHO
