RCU Forums - View Single Post - backwards switch
Old 01-13-2008 | 12:36 AM
John616's Avatar
John616
Default RE: backwards switch
I had this happen to me also. It is not a bad switch. In my case I had the wrong plug in the Rx. If you look at the switch harness it has two wires coming out of one side and one wire coming out of the other side. Make sure you have the one wire side pluged into the Rx. The two wire side is the battery connection and the charge receptical. Hope this makes sense...
