 backwards switch >
backwards switch
backwards switch
Old 01-12-2008 | 12:28 PM
Default backwards switch
While putting together a pulse xt i hooked everything up and noticed the receiver lit up as soon as i plugged it in and then when i turned the switch on the side of the plane "on" it went off is this just a simple fix of turning the switch around to where the "off"and "on" are reversed or is something else needing attention?
Old 01-12-2008 | 12:29 PM
Default RE: backwards switch
By the way this is a plug n play kit!
Old 01-12-2008 | 12:53 PM
RedGN's Avatar
just switch label.
Old 01-12-2008 | 02:21 PM
acarter's Avatar
ulscrew the label, and flip it around so it is right. It was probably put together wrong at the factory.
Austin
Old 01-12-2008 | 04:36 PM
Missileman's Avatar
You can also remove the swith itself and turn it around if needed.
"SECRET" when installing a switch "off" should be toward the nose of the plane and "on" should be toward the tail.
The reason is simple. The wind flowing along the fuselage will help keep the switch turned on when flying and not trying to turn it off.
Old 01-12-2008 | 04:46 PM
ORIGINAL: Missileman
That must be some strong wind. I do the same but just in case my hand brushes the switch as I release the plane. It will tend to turn "ON" instead of "OFF".
Old 01-12-2008 | 04:49 PM
Ok thanks guys kinda a simple question but just had to be sure!
Old 01-12-2008 | 08:11 PM
It also help if its going through a tree [:@]
Old 01-12-2008 | 08:29 PM
Missileman's Avatar
ORIGINAL: Flying freak
Or a bug strike
I hit a bug once (I think it might have been a june bug) that not only left nasty stuff on my airplane but it hit so hard it actually cracked the cowl [&:]
Old 01-13-2008 | 12:36 AM
John616's Avatar
I had this happen to me also. It is not a bad switch. In my case I had the wrong plug in the Rx. If you look at the switch harness it has two wires coming out of one side and one wire coming out of the other side. Make sure you have the one wire side pluged into the Rx. The two wire side is the battery connection and the charge receptical. Hope this makes sense...
Old 01-13-2008 | 12:37 PM
Missileman's Avatar
ORIGINAL: John616
Not always true. Depends on the manufacturer I guess. I have some switches that are exactly the opposite. Test your switch to make sure.
Old 01-13-2008 | 02:28 PM
switch placement to which way is on or off is a personal perference..You make a good and valid point as to bumping the switch to on..but I am in full scale aviation as well..where everything forward is on or toward the windshield is on..Once I have started making forward on I don't dare reverse it now....I have never had a switch shut off in flight
