RCU Forums - View Single Post - How much CA?
Thread: How much CA?
Old 01-13-2008 | 12:52 AM
mmattockx
Default RE: How much CA?
ORIGINAL: kbear
You'll go through thin CA much faster than medium. It just flows so fast. I've used about 3 oz medium so far on my Hots build.
Wow, that seems like a lot. I have the wing and ailerons all framed up on a 40 sized Mojo, built mostly with medium and thin CA. I have used about 1/3oz of medium and 1/2oz of thin. I have used some wood glue as well for gluing the center rib assembly together, but almost everything else was CA. A much better way to use the thin is with applicator tips (if you don't already use them), they make the flow much more controllable and precise.
Mark
