ORIGINAL: John616
I had this happen to me also. It is not a bad switch. In my case I had the wrong plug in the Rx. If you look at the switch harness it has two wires coming out of one side and one wire coming out of the other side. Make sure you have the one wire side pluged into the Rx. The two wire side is the battery connection and the charge receptical. Hope this makes sense...
Not always true. Depends on the manufacturer I guess. I have some switches that are exactly the opposite. Test your switch to make sure.
