ORIGINAL: gfdengine204
All this talk about Titebond prompts me to ask, How do you apply it? I am working on my first balsa stick build, using thin and medium CA, where I pin my pieces and then squeeze the CA on the joints after the pieces are set.
Thanks!
for instance the wing ribs. just squirt it on the brace where the groove in the rib is and then the bottom edge and put on the wing. It is great. and you don't have to worry about ventilating
