12 FGA Software Programing Problem
Hi All
Anyone else having any problems programing their 12FG's?
It appears there are several software glitches I have uncovered while trying to program three aircraft. I do not know if this is only my unit or if it's a universal problem but I would appreciate your checking on this and letting me know.
Problem 1
Both slider switches will only yield a very small servo movement no matter what the End-point/AFR setting values. You can check this by asigning it to any function such as Flap, Elv, Ail, etc. and then going to the servo monitor and actually move the slider you just set up.
Problem 2
No matter what you do to set up the 3 position SD switch the programing arrow will not follow the switch position [it won't move at all]. As an example, set up the SD switch as the aileron D/R switch and try and program it. I guess this could be a bad switch but I would like to make sure this is not a software problem before I go to the trouble of sending it Futaba.
Thanks to all who may have any info on this.
So far my FASST conversion is going well but have not as yet flown it.
My biggest complaint has been the 12FG Instruction manual. As compared to excellent previous manuals Futaba has produced, this one is JUNK!
