RCU Forums - View Single Post - 12 FGA Software Programing Problem
Old 01-13-2008 | 10:03 PM
acw
Default RE: 12 FGA Software Programing Problem
I haven't seen this either on the 12Z which is about the same programing wise.
I would check both AFR and ATV. Also, do you see the small throw in the servo monitor? If you do, this is a software / config issue. If you don't it must be something in the rx / servo.
Arnaud
