RCU Forums - View Single Post - CMP Hellcat
Thread: CMP Hellcat
Old 01-16-2008 | 12:18 AM
  #1876
warks62's Avatar
warks62
My Feedback: (140)
Default RE: CMP Hellcat
Yes Horizon is the Distributor for these engines which are made by Zenoah.
Steve no pics but all I did was old school by making a long "U" with 5/32 wire that goes from one elevator half to the other half. Then silver soldering a control horn in the middle of the "U". I then cut a slot in the rear of the fuse to slide in the wire I made then using a fiberglass rod with Dubro bolt through 4/40 Ball Links at each end. That way I don't have to worry about anything coming loose that way. I then glued in the piece that I had cut out before then just puddy up the imperfections you made and it is ready for primer.
Randy
