RCU Forums - View Single Post - Thrust?
Thread: Thrust?
Old 04-13-2003 | 02:34 AM
Mustang Man-RCU's Avatar
Mustang Man-RCU
Default Thrust
If you want right thrust point the prop shaft to the right. You can build the thrust into the firewall when you build the plane or you can add it after the plane is built by shimming behind the motor mount with small washers. IE:
If you want right thrust place the washers between the motor mount and the firewall top and bottom on the LEFT side motor mount bolts.
Good Luck
Steve
