Ok, now I am affected, too, and two other german users as well.
My case:
http://www.rcgroups.com/forums/showt...89#post8937989
Meanwhile, one off the affected countrymen spoke to robbe, and got the following information:
- Yes, there is a problem. Press releases will be issued soon.
- The problem can be caused by either deep- discharging the battery, or by switching the TX on and off fast. (switch bounce)
- Apparently, some ZGUID TXes were delivered.
- The problem affects both the 6ex, the 7C and the TM7 module.
- Newly delivered recievers have the ZGUID! If they work with a given transmitter directly without binding, the transmitter has the ZGUID problem.
- When multiple Fasst systems are used, it makes sense for the pilots to contact each other.
- Should a system suddenly not work anymore with its recievers (my case), you should check the TX like mentioned above and be cautious while flying.
