Guys,
Thanks for the info - very helpful.
Just to confirm that I, nor do I believe the others confirming my thoughts in this thread, are suggesting you can switch on 2 TXs on the same channel and all will be well!!
I was comparing the pros/cons of a 2.4ghz install vs the weatronic and the biggest Pro the 2.4 had going for it was the lack of being shot down. Now, if what is said on this thread is true, and there is no reason to question it, then the weatronic nudges ahead (in my mind) as the likelihood of someone being at my field on my channel generally seems to be low, the chances of them switching on by mistake whilst flying is even lower and now, with the resistance of the Wea to wayward signals, the chances are even lower. Probably low enough for me to stick with the Wea for now.
But, should the Wea boys rock on up with a 2.4ghz version of the wea then I'll show you a company that just took the market hands down!!
Rgds,
Mark
