ORIGINAL: taylor152806
what if the motor leaks fule out of the front betwen the engine and flywheel not alot just a few drips. also when pushing the flywheel you get compression then loose it...
i agree with dennis, sounds like a bad front bearing, usually fuel will leak when shot between the engine and flywheel.
