Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
another glow plug question
Old 01-16-2008 | 10:49 PM
Default another glow plug question
so i have been blowing plugs like crazy. runs for about 5 mins and pop. i am useing traxxas long hot plugs. i have tried rich and lean. please help me plugs get pricey..lol
Old 01-16-2008 | 10:52 PM
Default RE: another glow plug question
first you need to say what car?
Old 01-16-2008 | 10:54 PM
volcano .18vx sorry you are just the person i wanted to talk to. orings on the carb. any help
Old 01-16-2008 | 10:55 PM
how do i shut them pics off above my post
Old 01-16-2008 | 10:56 PM
lol you dont. Did you try osa3's? I wouldn't use long in the vx18. What oring on the carb? The needles?
Old 01-16-2008 | 10:59 PM
the orings on the neck there is 2 of them they are real thin.. the part that slides into the motor?
Old 01-16-2008 | 11:00 PM
drop me an email at [email protected]. I will check tomorrow at the store.
Old 01-16-2008 | 11:01 PM
with the carb off and i pull the pull start real slow and as it comes to tdc i hold pressure but not to much should it let go after a few sec, or is my engine junk?
Old 01-16-2008 | 11:03 PM
try rotating the flywheel and see the compression. Alot of times with the pull start , it will release like that.
Old 01-16-2008 | 11:04 PM
your probably running the engine too lean, thats why your burning plugs out. get the os a3, a great cheap plug: http://www.clermontmotorsports.com/s...A3-plug/Detail
Old 01-16-2008 | 11:08 PM
you are a great bussnes man, and a great friend to have. full of info wish you were closer. I need to buy a better truck i want to start racin not pro but maybe some day....
Old 01-16-2008 | 11:11 PM
PA's not that far from NY, lol. I dont sell redcats and i am not a dealer, just here to help out. If you want to race, pick up the monsoon, if you want to race, bash and have a great time, get the avalanche, its a good racer and great jumper
Old 01-16-2008 | 11:13 PM
what if the motor leaks fule out of the front betwen the engine and flywheel not alot just a few drips. also when pushing the flywheel you get compression then loose it...
Old 01-16-2008 | 11:15 PM
make sure its not coming from the carb . If not then your front crank bearing might be shot.
oh and Eddie that had to be directed to me not you lmao.. jk
Old 01-16-2008 | 11:20 PM
ORIGINAL: taylor152806
i agree with dennis, sounds like a bad front bearing, usually fuel will leak when shot between the engine and flywheel.
