Gas Engine mounting
Hello all hope you all are well. This is my first gas engine mounting and I wanted you guys in the knoe to take a look. It is a DA 50 in a TF P 51 Mustang GS. It is mounted by creating a second fire wall to give me the distance I need to the Backplate. 1/4 inch AC Ply with 3/4 inch spacer between the 2 firewalls and DA 3 inch standoffs. I still need to seal the new FW to protect it and I still need to enlarge the hole in the new FW for sufficient breathing for the Carb. Does it look Ok ? Opinions welcomed. Thanks for all the Ideas you guys provide as well as help. Hope I will be able to do the same someday. Kevin.[img][/img]
