There has been a huge change to the raffle!!!!!!
The raffle is now even better!
The raffle is for 2.......that is right......2 Airplanes!!!
The first ticket drawn will get their choice of these 2 great planes. We will then draw a second ticket. So you get 2 chances per ticket!
33% World Models Ultimate (purple version)
Due to a mix up that is outside my control.......
The 42% Ultimate is being replaced with a 33% Ultimate of the same color.
It is currently in Vegas awaiting the drawing. I've updated some of the earlier posts to include this.
33% Utlimate
Specifications
Wing Span : 76 in / 1930 mm
Wing Area : 2100 sq in / 135.5 sq dm
Flying Weight : 23 - 25 lb / 10440 - 11350 g
Fuselage Length : 82 in / 2080 mm
Engine Required : 100cc Gasoline
Radio Required : 6-channel radio w/ 9 servos
Key Features
High quality balsa and plywood construction
Light weight but strong for aerobatics maneuvers
Hand painted fiber glass cowling and wheel pants
Strong aluminum landing gear
All necessary hardware provided
I apologize to everyone and all ticket holders will be notified for a refund if they wish.
The raffle will continue though........There is still 2 planes to win....both more managable for cars and trucks to haul around.
36% PAU Edge 540
Wing Span : 105 in
Wing Area : 2123 sq in
Flying Weight : 26 lbs +/-
Fuselage Length : 98 in
Engine Required : 100cc gasoline engine
Radio: 6-7 Channel 8 High torque servos
Features:
* Cannister Ready
* Control surfaces pre-installed except rudder.
* Cowl installed with internal ring, mounting bolts are hidden.
* Aluminum main landing gear for durability.
* Covered in dark pearl yellow, blue, and silver using genuine Ultracote covering.
* Carbon fiber wing and stab tubes
* Fiber glass cowl and wheel pants
* Comprehensive hardware pack
Kit includes:
* CF wing and stab tubes
* PAU Aluminum horn set with hardened steel post's
* Genuine Dubro Ball links.
* Titanium turnbuckle pushrods
* Genuine Dubro Heavy Duty Pull-Pull system
* Genuine Dubro light main wheels, axles and wheel collars
* Graphic set as shown
* Haig style tail wheel
Tickets are $5 for one and 5 for $20.
Its open to anyone, not just the pilots! You can pay with cash, check, moneyorder, paypal (
[email protected]).....however you want. Mail/Online payments will be taken through 15 Feb. Winnner will be drawn right after the Unknown round on Sunday 17 Feb. Need not be present to win but winner is responsible for any shipping charges to get it from my house to theirs.
Please include your first choice of plane.
Thanks again
www.BuyRC.com
www.performanceaircraftunlimited.com
