RCU Forums - View Single Post - Byron Wedell Williams Racer Build
Old 01-17-2008 | 11:09 PM
Rocketman612's Avatar
Rocketman612
My Feedback: (85)
Default RE: Byron Wedell Williams Racer Build
Progress tonight. Finished the shear webs. The plans had you stop one bay in from the end and I extended them out between ribs 6 and 7. Care was needed to get the rear spar down in the rib as you worked out past rib 4. I was checking for squareness and ribs perpendicular to the board as I went along.
The aluminum spars were filed, straightened and cut per plans then test fitted and epoxied in place after the shear webs were done.
ID:	853862   Click image for larger version
ID:	853863   Click image for larger version
ID:	853864   Click image for larger version
ID:	853865   Click image for larger version
ID:	853866   Click image for larger version
ID:	853867   Click image for larger version
ID:	853868   Click image for larger version
ID:	853870   Click image for larger version
ID:	853871   Click image for larger version
ID:	853872   Click image for larger version
