ORIGINAL: Daemon
As I've said several times over on RCG, the only viable workaround is to get a known ZGUID bound Rx (it's been
reported that all brand new unpaired Rx's come ZGUID bound), and test your Tx against it (see if you can make it respond to your Tx)
before you turn on. Every time. Get one for yourself if you're really paranoid, or at least get one
for the whole club, and the only rule is
"Check with the ZGUID Rx before you turn on and again after you turn on. If it ever moves, then find the ZGUID Tx that's controlling it, and turn it off."
That's it.
ian
Do you seriously think that's an acceptable long term solution? Who the heck wants to put up with that? Not me? The benefit to FASST is supposed to be less worry, not more worry.
