Menace Flat Spins
Maybe not enough throttle or rudder. How many degrees of throw does your rudder have? You generally want at least 40, mine is around 50 - 55.
Is your plane staying flat or is the nose pointed slightly downward?
CG will also play a part in it too if it is too far forward.
