RCU Forums - View Single Post - the hyper st PRO thread!
Old 01-18-2008 | 11:54 AM
  #525
vnmsgt's Avatar
vnmsgt
Default RE: the hyper st PRO thread!
ORIGINAL: pbguns16
will these work on the stock rims.. ???? if now any other recomended tires from amain.. trying to put a order in but held of because wasnt for sure..
http://www.amainhobbies.com/product_...ducts_id/10569
Thanks Erik
No they will not fit. The stock PRO wheels are the same diameter as the new LPR wheels that are out but the stock wheels are a 12" wider than LPR's too. Also any of the pro-line LPR tires will NOT fit the stock wheels. I know from experience. I tried to put a set of proline LPR holeshots on my stock wheels and the tires were to stretched out width wise because they are meant for the Losi (LPR)width wheels and also the lip that you use to glue the tires to the wheels is COMPLETELY different and will not even fit in there or come close at all. Hobao was stupid to make there own design on how there tires fit there wheels. I cannot find any foams that will fit right or other tires as of now.
