RE: General servo install help
RCKen,
Thank you very much for the fast and wonderfully clear install information-you should write the manual for Airtronics!
I figured that they grommes had to go there but when the mfg. made them, the grooves were only cut in 2 sides at a 90 degree angle and was impossible to install. After seeing your info, I found that the rubber from the 3rd side was not removed and after doing so it works great. I would have not got the eyelet in correctly without your photos.
I can now finish my model this weekend and ge it in the air.
Thanks again for the terrific help,
Best regards,
Wayne
