RCU Forums - View Single Post - RE: intake stack for OS carbs?
Old 01-18-2008 | 06:51 PM
Campgems
Default RE: intake stack for OS carbs?
I didn't realize that the discussion under the abouve subject was a manufactures only fourm, So I started this one to continue it. My last post to the above follows. I just added photos of the package tag from that stack.
Bax, you are wrong. I purchased a stack from tower a month or so back that was listed in teh 56 parts and I installed it on my O.S. 52 Carb, which has the same part number for the body. They are both "N" carbs. The 56 version in addition to the stack has a different barrel which changes the mix ratio in the mid range some. I haven't seen the parts list for the 81 yet, but I'm betting money that the same situation exist there where the carb is based on the 70's carb.
Don
ID:	854392   Click image for larger version
