RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 01-18-2008 | 10:59 PM
  #1130
craigteffe's Avatar
craigteffe
My Feedback: (24)
Default RE: DL-50 engine
I have an edge 540 with the dl 50 and standard standoffs. I have about 1/2 to 3/4 clearance and no trouble here. I would not cut hole in firewall unless i had trouble, first mount the engine and try it. Then if you have trouble cut hole or baffle the cowl.
I do not like the holes in the firewall for the fact that fuel will get into the inside of you fuse. And soak into the balsa. I have several engines and all of them would do it. the only ones that didn't was the side draft, because they are side draft carbs.
Just my 2 cents
