RE: ECU SETUP QUESTION
When you Bind the RX to the TX you should set your throttle to the failsafe position. During the binding process the failsafe is set.
learn your ecu at 70% atv and than reset the atv to 100% and bind your TX and RX with the throttle trim down and the throttle stick in the down position.
Alan
