ECU SETUP QUESTION
My Feedback: (55)
HI Guys,
I am just settin up my TITAN ECU for the first time. I have 10x with Spektrum Module and AR9000 RX. I was told to set FS at 100% ATV and Learn RC at 70% RTV (throttle CH)
so
First I did both procedures at 100% ATV and did not get FS.
Then I did as above and now I am constantly getting FS and LED Sequencing.
As you may know, when using spektrum module with 10X u are in PPM mode and the TX FS in not active.
Can someone tell me how to set up FS and Learn RC with 10x with Spektrum Module...
Jason
so
Jason
Set the End Points to +/- 100% for the throttle channel.
Put in the Binding plug and learn the failsafe for low throttle / low trim.
Remove binding plug and reset the End Points to +/- 50%.
Learn R/C.
Test failsafe by shutting off the transmitter and making sure you see the 'F' appear on the GSU top center display.
Putting the End Points to +/- 50% still gives you about 500 throttle settings for the total stick travel.
Learn R/C.
NJ
When you Bind the RX to the TX you should set your throttle to the failsafe position. During the binding process the failsafe is set.
learn your ecu at 70% atv and than reset the atv to 100% and bind your TX and RX with the throttle trim down and the throttle stick in the down position.
Alan
Alan
