Hey Capt,n
Thanks for your input.....I just got the back plate today, boy it is nice!! Thanks Rich.!!
As far as the hole in the firewall....I really don't believe that I'll have to go that route. The DA50 that has been put in this aircraft and only has about 1/8" more clearance than my DL...and there is no hole being drilled. The DA has been running great in aircraft.
If I was to drill a hole in the firewall what size hole would you put in there?
Well the clearance meets the requirements...so I'm thinking it should be fine. I guess I don't relish the idea of weaking the firewall either....makes me nervous......[
] I did however drill the breather hole for my P51 because of the mounting method used.
Have there been problems running the DL with the min. clearance BTW?
Thanks again for the info.
Talk to you later,
Mike
