RCU Forums - View Single Post - rotostart problem
Old 01-19-2008 | 12:49 AM
hrdcoreglf
Default RE: rotostart problem
As far as the starter box. That is a common problem. All you have to do is elongate the flywheel hole a little with a dremel. Don't go crazy, but you remove material from the chassis a little at a time until your flywheel makes good contact with the flywheel.
