RCU Forums - View Single Post - Smoke system question.......
Old 01-19-2008 | 01:48 PM
HAMMERDOWN's Avatar
HAMMERDOWN
My Feedback: (100)
Default RE: Smoke system question.......
All my jets and paint stir planes have smoke and I have used several Tam systems (the very best system available at present IMO) as well as the Sullivan and a home made-from-old-fuel-pump system and all worked great. I never used a second receiver and never had any glitches with 72mhz or since switching everything over to 2.4ghz. A separate battery is a good idea. Keep the pump and esc away from the receiver and you will be good to go. You will need a steel tube to go in the turbine exhaust area. You can find it at McMastercar if you are building a custom sytem.
