RE: My Tf Cessna Mods
I made my door hinges by slicing up some nylon hinges and then using styrene, CA and epoxy to make them look the part.
I then molded the entire part and resincast the passenger door hinges. The passenger door is not operable on my model.
The upper pass door hinge is my RX switch, which slides fore and aft.
The reason the nylon hinge had to be sliced up is that the "rings" were too wide on the stock hinge.
SDC
