ORIGINAL: Crash90
Do you guys usually hit the monokote with heat once the windex has dried?
I do Crash. After leaving it over night I use an iron on low heat with a sock. I also put a very small touch of thin CA on any corners or points that may peel up later.
Hope it helps.
