ORIGINAL: smaze17
was thinking the best way to mount this engine was as follows:
1/4X20 bolt, metal lock washer...into a blind nut with a nylon locking nut to end it......
sound good to you guys??
The GT-80 has a large footprint mount so you don't need anything between the mount and the firewall. I use 1/4" bolts .... small flat washer on the front of the mount under the bolt head, large fender washer behind the firewall and a nylon lock nut. Don't really need any lockwashers. I don't like blind nuts for large gas engines!
