GT-80 Mounting Question
Old 01-20-2008 | 09:10 PM
My Feedback: (60)
Default GT-80 Mounting Question
was thinking the best way to mount this engine was as follows:
1/4X20 bolt, metal lock washer...into a blind nut with a nylon locking nut to end it......
sound good to you guys??
Old 01-20-2008 | 09:23 PM
soarrich's Avatar
My Feedback: (98)
Default RE: GT-80 Mounting Question
Assuming a wooden firewall, it sounds good, but I'd used a fender washer instead of a lock washer.
Old 01-20-2008 | 09:35 PM
My Feedback: (60)
cool..thanks rich.....so u think just a regular flat washer would be fine?
Old 01-20-2008 | 10:21 PM
My Feedback: (19)
ORIGINAL: smaze17
The GT-80 has a large footprint mount so you don't need anything between the mount and the firewall. I use 1/4" bolts .... small flat washer on the front of the mount under the bolt head, large fender washer behind the firewall and a nylon lock nut. Don't really need any lockwashers. I don't like blind nuts for large gas engines!
Old 01-20-2008 | 11:44 PM
soarrich's Avatar
My Feedback: (98)
smaze17
Do it like Truckracer said, I pictured it wrong.
Dont just use a flat washer, use the fender washer, it's much larger than a regular washer, get 1" or 1 1/4" washers at HomeDepot.
Old 01-21-2008 | 03:38 PM
My Feedback: (60)
thanks fellas...
