RE: Mini Titan thread
Thanks Bill.
I wonder... do the spacers cause the blades to function less efficiently? Also, what other brands do you and the others like for your mini-Titan? Which manufacturers have direct-fit (no spacers needed) blades? Being a beginner to heli's, I would like something less expensive than carbon fiber for learning as they will likely need replacing often.
Dave D.
<You can use different manufacturers' blades (I've actually never used the stock ones). You will need spacers for most upgrade blades, though.>
