RCU Forums - View Single Post - renegade rigger?
Old 01-21-2008 | 08:36 AM
GRANT ED's Avatar
GRANT ED
Default RE: renegade rigger?
ORIGINAL: NitroNuisance
Can you order a kit w/o motor since the motor they give you runs so hot? Are they cooled, I'm guessing they aren't? Even though they are an outrunner you could make a brass cooling coil couldn't you?
You can order the kit without the motor. You cant cool the motor. Being an outrunner makes this impossible. They only run hot if you run an agressive prop. With the standard prop that comes with the hardware kit you can run all day. I use a modded metal prop. This gives extra speed at the expence of run time.
