RE: SIMJET 1700
WOW!! The latest installment:
1-The ECU Came alive!!
2-The IR Transmitter became too hot to touch, still not transmiting to readout
3-Try to plug in Turbine and starter, try to do a start up, Surprise!! the Starter spins the turbine!
4-Plug in the rest, power up, the motor pump started running!!.. back to Square One!!
Suppose i should change the ECU to Gaspar Fadec!!
