RCU Forums - View Single Post - E-SKY honey bee KING 2. tail problem. and how to make it staty.
Old 01-21-2008 | 02:02 PM
kketron
Default RE: E-SKY honey bee KING 2. tail problem. and how to make it staty.
A question in conjunction with this thread - on my HB King 2, the servo horns have 3 holes across the top, and 5 holes down the middle shaft. On my 3 swash servos, the link rods are connected to the center hole out of the 3 across the top of the horn. On my tail rotor servo, the linkage is connected to the third hole down the middle part of the horn. 1) Is this the correct set-up, and, 2) wouldn't connectong the tail rotor linkage to the center hole across the top give a little mor range of movement? Is there an adjustment that should be made here? Thanks, Ken
