ORIGINAL:
[email protected]
are you F*****G SICK THE STOCK PIPE SUX BALLS DO U EVEN NO WHAT THE EXHAUST DOES IT ALLOW A FREEFLOW FROM ENGINE TO THE OUTSIDE OF STINGER(OUTSIDE AIR) AND THIS ALLOWS MORE FUEL TO BE PUSHED INTO THE ENGINE ALLOWING MORE POWER DON'T TALK ABOUT **** YOU DON'T KNOW ABOUT DUDE.
I don't think you should be the one shouting about not talking about what you don't know about...
The 'tuned' part of a tuned exhaust takes into consideration the diameter and length of the header, the length of the convergent cone, the length of the barrel, the length of the divergent cone, and the length, and diameter of the stinger.
If they could have put all those factors together in a 'cool dual exhaust' look, and made more power, then they would have done it years ago, and made it the standard.
Another note:
Take a quick glance through the paragraph directly above the text box you reply in....You know, the one about cursing, flaming, degrading, and insulting.
There are a lot of people here who have a lot of experience, and knowledge. Don't assume that just because you use the CAPS LOCK key, you will be right.
