RCU Forums - View Single Post - the hyper st PRO thread!
Old 01-21-2008 | 11:29 PM
  #573
rican25
Default RE: the hyper st PRO thread!
ORIGINAL: nwolsink
Finally some pics of my ST Pro, I run it with Jammin Big Bores with 50wt front and 40wt rear. In my diffs I run 7k(f) 10k(c) 2k(r), all oils are from Mugen Seiki
The current engine is a OS .30 VG which I mainly use to bash araound, the stock pipe will be replaced for a Jammin JP-3
My 2nd engine is an OS .21 V-Spec which I'm gonna use for racing, I run a OS 2060 pipe on that one or the JP-3
I've upgrade the C hubs to alloy ones and performed the Hyper 8 receiver box mod as wel.
Nice paint!! could you post a close up of the carbon fiber truck bed? I am thinking of doing that same thing just not sure on how to get in the grooves and have the pattern be as nice and defined as the flat areas. How did you do it? I am thinking of cutting the material and laying it down inside then spraying..... could use some help. thanks.
