RE: Need Help With Blade CX2
Do the newer CX2's not have a proportional trim pot on the 3 in1? I know in my manual it had a detailed explanation of trimming yaw out of the heli after all the mechanical adjustments were spot on. Agreed one should be checking for binding in that lower shaft and also the main bearings in the frame but after that its all about motors spinning proportionally to offset each others torque.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
