RCU Forums - View Single Post - BlueJay Models Dirty Birdy
Old 01-22-2008 | 10:56 PM
rainedave's Avatar
rainedave
Default RE: BlueJay Models Dirty Birdy
David, Dynamic Balsa does have the Escape cores. Measuring off the plans, the root chord and span of the Escape and XLT cores are the same. The Escape has a little more sweep and the cores have a 6" tip chord whereas the XLT cores have a 7 1/2" tip chord. The Escape cores can therefore be used on the XLT fuselage, you'd just have a little bit more LE sweep and bit less overall wing area. You can tell I'm not a hardcore purist.
David
ID:	858621   Click image for larger version
