RCU Forums - View Single Post - OS SPEED .21 V-SPEC engine
Old 01-23-2008 | 06:41 AM
Streakykel
Banned
Default RE: OS SPEED .21 V-SPEC engine
ORIGINAL: SManMTB
ORIGINAL: supertib
ORIGINAL: Streakykel
Like the bearings are ceramic, the crank has better balance and the ports are timed better.
is the port timing advanced or retarded from a stock V-Spec ?
If the power is higher in the rpm band the timing is most likely higher than stock.
More Advanced.
