RCU Forums - View Single Post - PT40 wing advice
Old 04-17-2003 | 03:44 PM
FLYBOY's Avatar
FLYBOY
Default PT40 wing advice
If you go with bolts, use nylon bolts and make sure to use the propper drill before you try to tap it. I have seen many people use a 1/4 inch drill and then the tap just drops right through. Look at the tap and it will tell you which numbered drill to use. Buy that bit. it will make a better hole.
