RCU Forums - View Single Post - Does anyone have the H9 Extra Easy II?
Old 04-21-2003 | 10:04 PM
JayDCC69
Default Does anyone have the H9 Extra Easy II?
I have the Xtra Easy and the Xtra easy 2 trainers. The Xtra Easy with the MDS was a JOKE. First off, replace that small inefficient JR 600MAH battery on there. I put in a Skyborn LiIon 1400 pack. Second, I replaced the engine with an OS 65 LA and a 12x8 prop. Third the nose wheel was replaced with a better spring type and mount (Springs on each side) along with the landing gear mount reinforced with extra plywood inside and then used REAL axles on the main wheels and not the cheap flat head screw axles.
I did the same with the Extra Easy 2 however the engine was a tad better
Anyone wishing to sell an Extra Easy or Extra Easy 2 email me at [email protected]. I dont need the radio with it NOR the engine. (Everything else intact - need the receiver)
