RCU Forums - View Single Post - Need Help With Blade CX2
Old 01-24-2008 | 01:41 PM
BryFlyGuy67's Avatar
BryFlyGuy67
Default RE: Need Help With Blade CX2
I use Tri-Flow (or equivelant, with PTFE) on my bearings and a drop or two on the swash every now and then. However, I have an aluminum swah. Do not lube a plastic swash.
As far as procedures, I usually take them out, put them on a paper towel and put a lot of lube in them to flush out any dirt / metal shavings that might be inside. I also change my bearings periodically, when my CX2 isn't flying right and I've checked everything else!
